February 11, 200818 yr Im going to go back thru the engine and check all the new parts i just installed. See what kind of condition they are in and just maybe i might find or fix the problem. Im also going to pull off the fuel pump and see how its doing.
February 11, 200818 yr Author heres a thread that explains what is going on. http://www.ultimatesubaru.org/forum/showthread.php?t=84476 since this thread ive done the following: Cleaned MAF Cleaned IAC Checked the connectors on CTS. (no green or corrosion what so ever) Checked the connectors on MAF, TPS, and IAC Replaced the O2 sensor Replaced PCV valve
February 11, 200818 yr you really should continue in your other thread, this will keep things easier to follow for us you can ask a moderator (via PM) if he/she (do we have female moderators here?) can merge the 2 topics As for helping you with your problems, we really need to know what kind of performace parts you put on, parts numbers, brands, anything you know. As the common consensus is that performance parts for these cars do not exist, so you very well may have something that is not meant for your car/engine.
