brokebill Posted February 14, 2008 Share Posted February 14, 2008 Moe runs pretty good with timing set right , but when i advance it 2 degrees i can tell a big difference in power. is this ok or will it cause trouble in the long run? Quote Link to comment Share on other sites More sharing options...
Stevethefolkie Posted February 14, 2008 Share Posted February 14, 2008 So long as you're not pinging you should be fine - if you ARE pinging go up a grade in gas (unless you want to retard the timing and lose the power) - Quote Link to comment Share on other sites More sharing options...
brokebill Posted February 14, 2008 Author Share Posted February 14, 2008 nope no pinging. people think im crazy but i've always used amoco/bp 93 octane in all my cars. i ran a tankfull in an old falcon i had 20 yrs ago and it made such a difference i've used it ever since. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted February 14, 2008 Share Posted February 14, 2008 I never ran my EA81 or EA82's at stock timing. I always bumped it up a notch or 2. The performance increase is noticable. they want it at 8 degree's (for a EA81) for emissions purposes. I ran mine at 10-12 degree's. Depending on your elevation. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 14, 2008 Share Posted February 14, 2008 gatlinburg..nice, i'll be there tomorrow. anyway, a board member here dyno'ed his XT6 (EA82 + 2 more cylinders) through intake, exhaust, cam, and timing changes. the timing change made the largest hp improvement so says the machine. i forget what he bumped it but he has to run 93 octane which you're already doing. Quote Link to comment Share on other sites More sharing options...
EvilDead Posted February 14, 2008 Share Posted February 14, 2008 I never ran my EA81 or EA82's at stock timing. I always bumped it up a notch or 2. The performance increase is noticable. they want it at 8 degree's (for a EA81) for emissions purposes. I ran mine at 10-12 degree's. Depending on your elevation. For someone who lives at 10,000... How many degrees advance? Quote Link to comment Share on other sites More sharing options...
brokebill Posted February 14, 2008 Author Share Posted February 14, 2008 when setting my timing i disconect and plug the 2 vac lines on my distributor, set the idle at about 700 like it says. it has a very slight miss and my timing mark isn't steady. it kinda drifts back and forth a couple degrees so theres a little guessing involved. the drifting is consistent (if that makes sense) not wild but wondering what might cause this. also should i change plug gap or anything to optimize performance? Quote Link to comment Share on other sites More sharing options...
brokebill Posted February 14, 2008 Author Share Posted February 14, 2008 gatlinburg..nice, i'll be there tomorrow. anyway, a board member here dyno'ed his XT6 (EA82 + 2 more cylinders) through intake, exhaust, cam, and timing changes. the timing change made the largest hp improvement so says the machine. i forget what he bumped it but he has to run 93 octane which you're already doing. im actually taking off for a couple days so sorry i'll miss you. and there is a tunnel between gatlinburg and pigeon forge with one lane closed so be warned traffic will be a b*tch. enjoy you stay. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted February 14, 2008 Share Posted February 14, 2008 i usually bump up to as much as 25 or 27 deg. 25 deg is just fine on pump gas. spfi and carbs are set for 20 deg. this helps her rev out inthe higher rpms and runs more smoothly with my open exhaust. in my conjuncture of various exhaust setups i find you can tune the timing to the exhaust pulse. you can almost hear the exhaut pulse move up and down the pipe and then tune it to where the pulse is right at the end of the pipe. i run a 2 inch cherry bomb immediately after the y pipe and then 1 3/4 or 2 inch pipe to the rear axle, then end there or turn out to the side how is gatlinburg? i went through there twice on 2006 and 2007 BABE rally. "Nug" from the board here went on this trip too. i was the one in the crazy toyota camper withthe u-haul trailer behind it, following the beat up VW van withthe words in tape 'show me your I' after the park rangers made them take off the t,the t, and the s Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 14, 2008 Share Posted February 14, 2008 and there is a tunnel between gatlinburg and pigeon forge with one lane closed so be warned traffic will be a b*tch. enjoy you stay.DUDE! thanks for the heads up, i'm glad i said something. is that going towards GB or away from GB? Quote Link to comment Share on other sites More sharing options...
