March 11, 200818 yr Nope, but I did a search and came up with this wonderful link http://www.ultimatesubaru.org/forum/showthread.php?t=24980 2'' kits aren't a common one, but the link above should give you some ideas.
March 11, 200818 yr cut 6 - 2x2 square tubing 1-1/2 long , drill 3/8 holes in them and mount them on top of the struts, the axles can take it , and yes the wheel camber is effected but you wont notice it driving it SJR
March 11, 200818 yr Author 2x2 squares. I like the sounds of that, easy...and i have 2x2 laying around. Are there any pics of this mod out there? this will get the buggyroo level and possibly stop the swampers from being cut when landing from a jump. Next buy is a roof rack, full size spare and possibly 1.5-2" wheel spacers.
March 11, 200818 yr and possibly 1.5-2" wheel spacers. Just a comment on spacing your wheels out further. It may give you more clearance on the inside, but will give you less clearance at the rear portion of your front wheel wells when turning the wheel sharp left or right. You may want to consider keeping your wheels tucked in as tight as you can. Rollie
March 11, 200818 yr since its on a buggy, make sure you weld the peices together. You should also consider some seem welding if you havent already.
March 11, 200818 yr I guess this is a good place to post my unfinished website.One of the only things that i have actually finished is my step by step on lifting an ea82 tha way i did. http://www.subazero.com.
