off length drive belts?
i have a legacy with a non-stock drive belt set up in it. i need a 4 or 5 rib 28 inch serpentine belt. local stores don't have anything that will work...all i can find locally is 25" and 31.5", nothing in between.
looking on line i can't find places that sell belts other than by model/make/year, which won't work here.
suggestions?
autozone can get one that is 27.5 thats where i got mine at, thats what i had to use on my ej since i didnt have power steering. they had to mesure a few but the have it wish i had kept the part number
ah no kidding, exactly what i need. no autozone's around here. maybe i can call one, get the part number and order on line or something like that.
thanks.
thanks guys. Autozone guy was good, took about 20 seconds to figure it out over the phone. Had one in stock but unfortunately it's not very close.
275K4 is the Autozone part number, i'm assuming that's a 4 ribbed belt given the K4 on the end.
since advanced auto parts is 1 mile from work i just ran over there and they had the 4 ribbed 27.5" belt in stock as well. thanks for the help kiddo's!
thanks.
Try http://www.autozone.com. You may be able to buy the belt you want from their website. The website tries to steer you to a store, but if you look carefully, you can buy their products on line.
it's sort of impressive how long i've driven it/run it with the optima battery in there and no alternator! but relief is in sight now.
[...]275K4 is the Autozone part number, i'm assuming that's a 4 ribbed belt given the K4 on the end.
That's an "industry standard" number; it should "translate" as follows:
275 = length in tenths of an inch = 27.5 inches
K = cross-section, typical for automotive application (others are H, J, L, M)
4 = number of ribs
For a good laugh, read the "Key Features" of the Prestone version at http://inpcars.com/serpentine1/242.html .
I assume that's a botched translation from (perhaps) Chinese.
4 = number of ribs
lol I thought I had read some dumb stuff till I read that, they weren't even sentences!
