April 12, 200818 yr Considering I have the manual button, for the secret handshake, I ought to be able to figure SOMETHING out LOL
April 12, 200818 yr Author you did the same swap i did - 95 into a 96. i guess you swapped the rear diff to match? i didn't know what to think since i swapped AWD to FWD and EJ25 to EJ18, but since yours was just the trans i'm wondering if we won't have the same codes. be interesting to see. i assume you're going to try and pull the code?
April 13, 200818 yr Ok, this thread just became relavent to me. I swapped a '95 OBD1 trans into my SVX & have the flashing AT TEMP light @ startup. Mysteriously, I also have no FWD light with the fuse in. Factor this into your thoughts on this issue.The car drives flawlessly, still does the torque interrupt during shifts, and generally works as advertised. For the record: Trans is a '95 Impreza 4.11 AWD Car is a '96 SVX do you have torque bind. when my 95 leg sedan with a 96 leg wagon auto trans got torque bind and a flashing AT temp light i put in the fuse and the FWD light came on and the flashing light and TB went away. we drove it like this for a while. then, occasionally, the torque bind and flashing light would come back even with the fuse in. when this happened the FWD light would go out. conclusion, if you put in the fuse and the FWD light comes on the duty c is working, if the FWD light doesnot come on then the duyt c is not working. i haven't studied this problem in depth so my conclusion may be wrong, but the facts are correct. in my car, if the duty c is not working the fwd light will not come on. we finally removed the rear section of drive shaft until we replace the duty c.
April 13, 200818 yr the phase 2 trans, 99 and up, has at the very least, 2 more speed sensors. i think they are internal. they are the simple one like the one on the rear extention housing. this by it self adds 2 more wires to the wiring harness / connector. i don't know what other changes they may have made in 99. Can you show any literature or pics to back this up? Considering that the TCU already recieved speed signals from 2 sensors, I don't understand why 2 more would be added?
April 13, 200818 yr Mysteriously, I also have no FWD light with the fuse in. Factor this into your thoughts on this issue. installing the FWD fuse connects a signal circuit on the TCU to ground. One side of the fuse holder is connected to the TCU, the other should be bolted straight to the car body for ground. Fairly close to the FWD fuse holder itself. Check that the grounded side of the fuse holder actually is grounded.
April 14, 200818 yr Can you show any literature or pics to back this up? Considering that the TCU already recieved speed signals from 2 sensors, I don't understand why 2 more would be added? my first clue was the different connectors with different number of pins between the 99 phase 2 and the 95-98 phase 1. for 10 years they had been using the TZ102Z... series trans, in 99 they went with the TZ1A2Z...... 2ND was an ad on ebay for a trans wirring harness, the one that goes into the the trans case, for a 99 outback auto trans. it had more wires and what appeared to be 2 more of the speed sensors like the one in the transfer case. 3RD some one posted a link to a 99 trans diagram of some kind and it showed me something to confirm my thinking. the added sensors could be temp or something else but they looked like the speed sensors to me. but i'm not an engineer nor a subaru expert, so i could be wrong.
April 15, 200818 yr do you have torque bind. when my 95 leg sedan with a 96 leg wagon auto trans got torque bind and a flashing AT temp light i put in the fuse and the FWD light came on and the flashing light and TB went away. we drove it like this for a while. then, occasionally, the torque bind and flashing light would come back even with the fuse in. when this happened the FWD light would go out. conclusion, if you put in the fuse and the FWD light comes on the duty c is working, if the FWD light doesnot come on then the duyt c is not working. i haven't studied this problem in depth so my conclusion may be wrong, but the facts are correct. in my car, if the duty c is not working the fwd light will not come on. we finally removed the rear section of drive shaft until we replace the duty c. I'm also running with 1/2 a driveshaft, as I didn't have the rear diff to swap in. So, what you're saying is, when the duty C dies, The FWD light goes out. Interesting. As for pulling codes. I may have the Manual sw., but I don't have a stinkin' power light, so no way to output the stupid codes!
April 16, 200818 yr I'm also running with 1/2 a driveshaft, as I didn't have the rear diff to swap in. So, what you're saying is, when the duty C dies, The FWD light goes out. Interesting. As for pulling codes. I may have the Manual sw., but I don't have a stinkin' power light, so no way to output the stupid codes! i don't reall know if the procedure is the same for cars without the power light, but i think the power light was replaced by the AT TEMP light for trans warning purposes. maybe for code reading as well????
April 18, 200817 yr my first clue was the different connectors with different number of pins between the 99 phase 2 and the 95-98 phase 1. for 10 years they had been using the TZ102Z... series trans, in 99 they went with the TZ1A2Z......2ND was an ad on ebay for a trans wirring harness, the one that goes into the the trans case, for a 99 outback auto trans. it had more wires and what appeared to be 2 more of the speed sensors like the one in the transfer case. 3RD some one posted a link to a 99 trans diagram of some kind and it showed me something to confirm my thinking. the added sensors could be temp or something else but they looked like the speed sensors to me. but i'm not an engineer nor a subaru expert, so i could be wrong. I know at least one additional sensor is the torque converter speed sensor. That's just from memory. I'd have to lookup what else has changed.
April 18, 200817 yr I pulled my codes, yep the AT TEMP gave them to me. I have one code...Duty C. So... I'll be cracking the case on my old tranny to pull it. I'll swap it in when I get the cash to buy a 4.11 rear diff to swap.
