Strut mount bearing - how hard to replace?
While replacing the front axles on my 2000 OBW I noticed that the driver's side top strut mount moves quite stiffly (when compared to the passenger side), which would explain the audible groan when turning at low speeds. How hard is it to replace the bearing, or must the entire top mount be replaced? TIA.
You are looking to replace the upper strut mount.
Not hard at all, but you must own the tools to do it, the spring must be compressed, and held (safely), while you remove the top nut, and replace the upper mount.
