April 22, 200818 yr Heres my new car plans are to lift it 4" build some offroad bumpers put on some big meats install a dual range
April 22, 200818 yr Author where ya getting the dual range for an EJ?!chris any old EA82 D/R will do, use the adapter ring and a redrilled flywheel from a EA and modify the drive line and run Impreza FWD front axles:eek: :cool: ,so instead of "EJ it" for the EA cars its "D/R it " for the EJ cars:grin:
April 22, 200818 yr any old EA82 D/R will do, use the adapter ring and a redrilled flywheel from a EA and modify the drive line and run Impreza FWD front axles:eek: :cool: ,so instead of "EJ it" for the EA cars its "D/R it " for the EJ cars:grin: should've known you'd have it figured out already. "D/R it" baby!! chris
April 23, 200818 yr any old EA82 D/R will do, use the adapter ring and a redrilled flywheel from a EA and modify the drive line and run Impreza FWD front axles:eek: :cool: ,so instead of "EJ it" for the EA cars its "D/R it " for the EJ cars:grin: don't forget the rear end. the one in there would be a 4.11 and you need a 3.90 for the DR. fortunally they came in tons of imprezas and 2nd gen legacys can't wait to see it when your done
April 23, 200817 yr and you need a 3.90 for the DR. fortunally they came in tons of imprezas and 2nd gen legacys And Automatic 1st gen legacies and almost any 85-94 4wd non-turbo GL/Loyale All have the same external splines, bolts right up.
April 23, 200817 yr And Automatic 1st gen legacies and almost any 85-94 4wd non-turbo GL/Loyale All have the same external splines, bolts right up. all the first gen autos i have seen had 4.11s in them too. but that was the great part about having the sticker on the old ones, just look and see. too bad they stopped doing that.
April 23, 200817 yr I can't wait to see the fenders peeled off of this one Scott! The marker lights are already trembling!
April 23, 200817 yr all the first gen autos i have seen had 4.11s in them too. but that was the great part about having the sticker on the old ones, just look and see. too bad they stopped doing that. Nope, check the FSMs All first gen 4eats in Legacy were 3.9 Manuals were 4.11
April 24, 200817 yr Nope, check the FSMs All first gen 4eats in Legacy were 3.9 Manuals were 4.11 crazy, i guess mine was an oddity or someone swapped the rear cover for a one that said 4.11s
May 3, 200817 yr Author Heres my new carplans are to lift it 4" build some offroad bumpers put on some big meats install a dual range OK hows my list coming, so far have done some on the lift still along ways to go, got a line on some used 27" BFG AT s , got the axles for the Dual range swap ,been driving the car daily I realy like the car, even installed a cd player its been 4 years sence i had a radio in the car even caught a mouse
May 3, 200817 yr Nope, check the FSMs All first gen 4eats in Legacy were 3.9 Manuals were 4.11 i think you got that backwards. most manuals were 3.9 and most A/Ts were 4.11. later when outbacks came along A/Ts were 4.44 and manuals were 4.11. but first gens weren't as consistant. but to be sure look here: http://www.northursalia.com/techdocs/trannychart/trannychart.html i used to have a book markj for another forums' post listing all the trans a/t and manual, but when my computer died last month i lost a lot of saved stuff.
