April 26, 200818 yr Does anyone know where the engine ground terminals are located? I need to check if those are tightened. Thanks!
April 26, 200818 yr You need to tell us what you're working on. But generally speaking most newer subies have 1 or 2 on top of the intake and the ground cable for the battery goes to by the starter.
April 26, 200818 yr Author You need to tell us what you're working on. But generally speaking most newer subies have 1 or 2 on top of the intake and the ground cable for the battery goes to by the starter. Well, I found a TCU code on my car using the "unique" method. The code was 45. So I looked up in my subscription to AllDATA and it says to check the engine ground terminals to see if they are tight. If not, then it says to tighten them. I just don't know what they mean by engine ground terminals and can't find a diagram as to where they would be.
April 26, 200818 yr There may also be a tranny ground strap. When in doubt add a ground. nipper Yes, some of them have a ground wire for the trans in the area of the pitch stopper.
April 26, 200818 yr Author Yes, some of them have a ground wire for the trans in the area of the pitch stopper. wheres the pitch stopper?
April 26, 200818 yr its the dog bone thing on the right side of the engine by the firewall. Someone will have a pic. nipper
April 26, 200818 yr It is very important to insure that the connections are clean and free of corrosion, otherwise it won't matter how tight they are. Here is a link to info on anti corrosion pastes that work very well. (probably more info that you need, but good reading). I have purchased Noalox at home depot, it is readily available. http://sw-em.com/anti_corrosive_paste.htm
