May 1, 200817 yr searched but no results. what kind of gear oil do i put into my rx's LSD. pretty sure it has never been changed in 166k thanks
May 1, 200817 yr When I rebuilt my LSD i used some Castrol LSD Additive with regular Diff Gear Oil. I did some research and found many who have done the same. I found both at my local autozone. -Brian
May 1, 200817 yr the redline stuff is recommended quite a bit here. saw Kendall limited slip gear oil recommended a few times. it's been a couple years since i changed mine so i don't remember. found this while searching: From the book: Fluid recommendations Use gear oil with API classification GL-5 for open differentials and GLS for limited slip differential. Viscosity should be: *SAE 90-above 30 deg F *SAE 85W-above 30 def F *Sae 80W-below 0 def F
