submonkey Posted December 31, 2003 Share Posted December 31, 2003 just got my engine in everything hooked up. BUT no run it's a EA82 turbo. I've got fuel and spark, but the disty might be off. I know the firing order is 1342, but what is the orientation on the motor. any tips would be appriciated. thanks jay 85 EA82 turbo wagon Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 31, 2003 Share Posted December 31, 2003 #1 is 1st one on the passenger side, odds over there, even on the other side. the front on the driver side should be #2 the wire on the back of the cap, closest to the clip/screw. is #1, counterclockwise rotation Quote Link to comment Share on other sites More sharing options...
submonkey Posted December 31, 2003 Author Share Posted December 31, 2003 thanks miles. i'll try it after the battery charges Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted December 31, 2003 Share Posted December 31, 2003 you should have referred to the repair manual first. Quote Link to comment Share on other sites More sharing options...
MorganM Posted December 31, 2003 Share Posted December 31, 2003 Originally posted by submonkey just got my engine in everything hooked up. BUT no run it's a EA82 turbo. I've got fuel and spark, but the disty might be off. I know the firing order is 1342, but what is the orientation on the motor. any tips would be appriciated. thanks jay 85 EA82 turbo wagon The firing order is 1324 not 1342. That might be where you should start looking If you have removed the dist. and reinstalled it then I would also look there more closely. Make sure it is not a tooth or 2 off. Make sure it isnt 180 off. Did you touch the timing belts? If so make sure they havent slipped a tooth and that they are properly installed. Quote Link to comment Share on other sites More sharing options...
submonkey Posted January 1, 2004 Author Share Posted January 1, 2004 thanks for all your help guys. disty was a tooth of and its running smoother then ever. Quote Link to comment Share on other sites More sharing options...
1ABAJA Posted January 2, 2004 Share Posted January 2, 2004 Glad to see you kept your ride! Josh! Quote Link to comment Share on other sites More sharing options...
submonkey Posted January 2, 2004 Author Share Posted January 2, 2004 Thanks, me to especially since we just got about 6 inches of snow. Quote Link to comment Share on other sites More sharing options...
