clutch sizes??
I need a new clutch for my 5spd 4 wheel drive its an EA82 , ive checked on buying a clutch and they say there are different sizes an i dont know which one i need? which one do i need?
D.D. 8-7/8; Spline 7/8; Teeth 21; or a
D.D. 8-7/8; Spline 1; Teeth 24; or a
D.D. 7-7/8; Spline 7/8; Teeth 21;
thanks
SS
225mm (8 7/8") is for 4WD. You need the second one with the 1" 24 spline disc hub. 4 speed 4WD, and 5 speed 2WD share the same spline count. 5 speed 4WD's use the larger shaft - thus what you need.
