June 10, 200817 yr I didn't put the Spfi on but I did put the EA82 carbed setup is on it. I kept the EA81 bellhousing on it and did Not use the Ea82 Bellhousing. I was wondering how to time this thing now.I used the EA82 flywheel. Did I mess up not using the EA82 bellhousing or do I time it just like a EA81. I hope I made sence. Jeff
June 10, 200817 yr What does this have to do with SPFI? 8 degree's BTDC. If you used the EA81 flyhweel then you time it normally. If you used the EA82 flywheel and didn't transfer the EA81 marks to it then you are going to have to create new marks on the crank pulley or flywheel..... 360 degrees in a circle - get out your compass. GD
June 10, 200817 yr Author I put it under SPFI to get others to look at this thread. Since its the same Idea I figured.......... anyways, I'll go buy a compass that should be a Pain in my you know what. Jeff
