()__1337_CRAYOLA__()> Posted June 14, 2008 Share Posted June 14, 2008 i put a expansion tank from a 1991 loyale on my 83 brat and since then ive i noticed i get bubbles in the expansion tank when the cars running and high pressure in the cooling system what could this be... the car doesnt overheat it runs at i would assume normal temp (the second mark on the gauge) about half way and the fan kicks on.. theres no coolant comming out the exhaust that i can tell it doesnt steam or anything... this brat is turning out to be a bad idea to buy haha or then again it could benormal im a toyota person but i moved to subaru to get gas milage Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 15, 2008 Share Posted June 15, 2008 Cooling system pressure should be 13 psi. EA81's do not need an overflow tank. Remove it. The system will seek it's own level - which is usually around 1 to 2 inches from the filler neck. It should not be full - it needs room for the coolant to expand as it heats. GD Link to comment Share on other sites More sharing options...
