Strange Transmission noise
95 Legacy 5mt 130K. Transmission is making a noise something like a clicking or clacking...whats odd to me is that is does not make the noise when cold. If I drive say 15 mins it begins. Most notable in third gear and fourth. It will also make the noise in nuetral if you get the rpms up around 3k. Also I can make the noise go away or lessen by moving the stick around (bushings are shot and stick moves quite liberally side to side while in gear). Also only makes the noise under load...let off the gas and it stops clacking. What say ye? I'm so perplexed as to why its dead silent when cold.
does anything happen to the noise when you are idleing and you push in the clutch pedal?
no. It sounds like something rattling in the bushings but if that was te case i would think it would rattle cold from the get go.
maybe the little spring that connects the shift rod to the stay rod broke and its hitting something.....i would def. first do a thorough visual inspection of the whole car......
I had a prob like that with a Mitsu Montero - the trans was losing the main bearings.
Ate 2 sets of bearings until I replaced all the gears PLUS the bearings (glad I was having work done at a local Comm College shop)
+1..i had same problem with the spring on my 94 legacy with sloppy shifter.
now i gotta find out why my 92 doesn't like 4th gear,almost feels like it's kicking it out of gear..to the point where i gotta hold it in gear.of course it doesn't do it with a load on trans,only if i let off gas..(gotta get under it one of these days and check trans mounts)
or it could be what grossgary said..check the heat shields too
It's definately not heatshileds..I can change the sound by moving the stick around. Fearing bearings. It'll be making a visit to the local guru as I somehow got a rock between the right fan and radiator and put a hole in the radiator...not fun when you're 300 miles from home and 30 from what some call civilization. Stop leak got me home...running 100 percent water. It seems to come in threes...I wonder whats next.
-QUOTE-now i gotta find out why my 92 doesn't like 4th gear,almost feels like it's kicking it out of gear..to the point where i gotta hold it in gear.of course it doesn't do it with a load on trans,only if i let off gas..(gotta get under it one of these days and check trans mounts)-QUOTE-
subie 94- my 96 had the exact same problem with 4th gear a few miles back....i checked all my mounts and they were all ok.....but eventually when i tried to hold it in gear it would grind its ars off...and eventually i lost 4th gear.....plus i needed a new viscous coupler....i ended up just replacing the trans with one with like 93,000 miles on it.....than again the origional held up good until like 190,000 miles.......anyways just thought i would share.....:)
yep good ol Charlie says "it's eating gears"...great. And 285 to replace a radiator!? How hard is that to do yourself? I think I can manage it but dont want to get in too deep...have two days off work though so I have time. Do you think changing the gear oil would be at all beneficial at this point?
radiator is pretty simple to replace.....drain system....pop off brackets.....hoses.....fans.......it kind off just pulls right out.......it shouldnt take more than maybe and hour or two...while your doing it you might want to consider also changing the upper and lower rad. hoses......it def. cant hurt to change the gear oil at this point.....besides you will get to see how much metal from your gears is on your drain plug.......
