January 3, 200422 yr Well in my messing with the dash, I did somethng that messed the heater up.. The air flow is stuck on Vent, but the off button still works.. Did I unplug a vacumn somehow putting my dash back together? Anyone have this happen or have a solution to what diaphrams I have to wire open or closed to get my defrost to work again.. Its -20F again so my car is pretty much undriveable without Defrost working
January 3, 200422 yr my car was "PERMANENTLY" stuck on defrost just re-check vac. lines, they are numberd here are all your answers http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=6915&highlight=defrost you should have searched connection 1 goes to the servo labled as "B" sits at app. a 45 degree angle on the side of the hivac unit (windscreen heat)
