August 13, 200817 yr So I am doing the 4spd 4x4 to the 5 spd 4x4 in my hatch, its an 86 GL ea81, so I have went step by step down this list http://www.ultimatesubaru.org/forum/showthread.php?t=49952 but i have made it down to step 20. transfer timing marks to ea82 flywheel if neededhow exactly do I tell if the marks need to be transfered I lined up the bolt holes and the timing marks did not line up. How would I transfer them if they needed to be transfered? Thanks SS
August 13, 200817 yr Why not just use the EA81 flywheel? That's what I always do. Just substitute the EA82 friction disc. GD
August 13, 200817 yr Author Why not just use the EA81 flywheel? That's what I always do. Just substitute the EA82 friction disc. GD wait so all that about putting in the ea82 flywheel isnt totally necessary?
August 13, 200817 yr wait so all that about putting in the ea82 flywheel isnt totally necessary? No - you just use the EA82 clutch disc. Swapping over to the EA82 flywheel just buys you the ability to run the EA82T/XT6 pressure plate. You need to make sure you use the EA82 disc that has the round hub and not the semi-square one as the squarish one won't fit inside the EA81 pressure plate. GD
