ea81 solid lifter engine cracked head?
As I told you before, you are not eliminateing blow by gasses. One of the byproducts of combustion is water vapor. It naturally cools and condenses in the area around the vent and mixes with oil already present there. The result is milkshake.
You are also going to acidify your oil, eat your bearings, and be a very unhappy Subaru owner if you keep up this foolishness.
