()__1337_CRAYOLA__()> Posted August 23, 2008 Share Posted August 23, 2008 what should the timming be andwhat connector do i connect and it has vaccum advance... treat this like a carb version and disconnect it? and is half temp for a turbo car to high.. i have a new radiator on the way i was just curious... i have a factory t-stat in it and it just runs at half temp and 3/4 with the ac on... needless to say i dont use the ac Link to comment Share on other sites More sharing options...
Turbone Posted August 23, 2008 Share Posted August 23, 2008 Timing info is on the underside of the hood. The green connector under the steering column needs to be connected to time it. Your temps are getting into the danger zone, especially for a turbo. Dont push it until you get the new rad installed. Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted August 23, 2008 Author Share Posted August 23, 2008 no info on the under hood ive got it parked so i dont hurt the rebuilt motor Link to comment Share on other sites More sharing options...
