November 19, 200817 yr 2 Questions for a 01 Outback H6 Wagon. 1 Where is the rear washer fluid tank filler? 2 Where is the fuse to disable the ABS system? Thanks for any help.
November 19, 200817 yr If the 01 is like my 99, the rear squirter washer uses the same reservoir that the windshield washer uses. There is just one squirter reservoir container under the hood.
November 20, 200817 yr Author Thanks. I had a 92 Legacy Wagon and it had a separate tank for the rear washer that's why I was wondering as I looked everywhere for it back there:o. Must have a plugged line somewhere. As for the abs fuse or relay I still need to find it.
November 20, 200817 yr Thanks. I had a 92 Legacy Wagon and it had a separate tank for the rear washer that's why I was wondering as I looked everywhere for it back there:o. Must have a plugged line somewhere. As for the abs fuse or relay I still need to find it. There is one tank, but it does have 2 separate motors/pumps, could be the motor for the rear, or a loose connection. Dave
November 20, 200817 yr In my washer tank, the pump for the back is higher up in the tank than the front. Therefore, the rear runs out first of washer fluid from the same tank. I hope that made sense. If after you check for clogs, make sure you fill the tank all the way up to test the rear washer.
