November 24, 200817 yr how do i get the steering wheel off my brat i put the lift in and messed up the wheel allignment
November 24, 200817 yr Theres two small diameter holes on the back side of the steering wheel. One on either side of the wheel.You need to put a small screwdriver into the hole and collaps the fastener which will allow you to pull one side away then do the other side. After that,lift the bottom of the pad and unhinge the fastener at the top of the pad. Disconnect your battery first. Otherwise your horn,well you know.
November 24, 200817 yr i have encountered screws too.do not know if someone put them in after the fact or if they were stock.tilt that baby up and see if you can get an angle on it to look with a flashlight,but it is probably what mark posted.cheers, brian
