2001 Outback radio councle disassembly?
Well I'm a little not so experienced with the newer gen cars. I was able to figure out how to pull apart the ea81's dash and the XT's dash, but on the Outback, I couldn't figure out what is holding the trim cover over the radio on at the bottom. I was able to detach the top half, as I had to replace my instrument cluster lights. Any insight? :confused: I appreciate it, thank you!
Yeah, the impreza's are way different. Single couple holder on this that folds out of the dash from a thin vertical slit. I unclipped everything but theres still something under the radio on the left side that is holding it in place, right next to the ash tray. This is an 2001 Outback Limited. Forgot to add that in the first post, my bad.:drunk:
-Carl
