December 6, 200817 yr 2003 impreza RS There looks like a bulb out directly between the tach and sepeedometer ---how do you get to it and is it a typical bulb that an autoparts store would have
December 6, 200817 yr It may or not meant to be there. Yes these bulbs are standard autoparts store fodder. If its like the legacy, the trim panel around the spedo needs to be removed, any switches in said trim need to be unplugged, then the dash itself comes out with a few screws and prbblu 4 big plugs and one little one in the center of the back of the cluster. Inspect all the bulbs and replace any that look old. I replaced all of mine actually when i had a bulb out and it made a huge differnce. nipper
