Auto Gauge Cluster Vs. Manual Cluster
The gauge clusters in question:
Auto - '97 OBW (2.5 with winter package if that matters)
Manual - '96 OBW (2.2 without winter package if that matters)
I want to know if they are interchangeable, ie does the manual cluster have the AT temp light? That would be the only difference correct?
Thanks!
Will-
manual cluster has no shift indicator section....
I don't think autos had it either after 95
Riiiiiight , I forgot about shift selection. Hopefully Gloyale is right...
what year did they switch to the Hall effect speed 0 sensor,
that the 97 uses,
verses the cable driven one?
Gloyale is correct as far as the 97's go,
my 97 does not have a shift indicator
My 97 Oh Bee
The clusters are completely interchangable, the light socket is there, you just need to put a bulb in before you put the cluster in. IIRC there is a light on the mt cluster that is un-needed for AT so just grab that one. The speedo might need to be swapped. The 96 goes to 140 and the 97 only goes to 120. I dont remember if the speed sensors were different or if the difference is in the speedo head alone.
