Wirebrush Posted January 24, 2009 Share Posted January 24, 2009 I'm going to retrieve a dead Brat. Can I tow it with several hundred miles with a tow bar without damaging anything if I have the trans and/or transfer "case" in neutral? If I have to rent a trailer or dolly it may not be worth it, but I can build a tow bar for very little. Thanks, Mike. Link to comment Share on other sites More sharing options...
The Scooby Posted January 24, 2009 Share Posted January 24, 2009 pull the back half of the drive line, or both rear axels. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 24, 2009 Share Posted January 24, 2009 EA81's should only have a single piece driveline. If you remove it you will lose all your gear oil from the tranny. With the Tranny in neutral, you should be fine. I believe it is only Automatics you will have problems flat towing. Link to comment Share on other sites More sharing options...
The Scooby Posted January 24, 2009 Share Posted January 24, 2009 thanks for clearing that up, i couldn't remember. Link to comment Share on other sites More sharing options...
Frank B Posted January 24, 2009 Share Posted January 24, 2009 Your not going to hurt anything at all with a manual tranny, just put it in neutral. You'll add some miles to the car, unless you disconnect the speedo cable. A manual tranny will still get it's lubrication because the gears are submerged in oil, an automatic only gets oil when the engine is turning the main shaft which drives the pump, they need the driveshaft removed. I've towed several manual cars and trucks without removing anything and they were fine. Link to comment Share on other sites More sharing options...
monstaru Posted January 24, 2009 Share Posted January 24, 2009 i flat towed a brat from yakima to spokane, and had no issues whatsoever....make sure you can leave the steering wheel unlocked for turning...........cheers, brian Link to comment Share on other sites More sharing options...
