bdecriscio Posted February 15, 2009 Share Posted February 15, 2009 Does anybody know if the neutral saftey switch (inhibitor) is the same thing that's called a transmission range sensor through diagnostics codes(Autozone print out calls it that). If not, where is the transmission range sensor located, I've already disconnected and cleaned the NSS, no drivability or starting problems, just the check engine light and stored PO705 code. Thanks, Bob Quote Link to comment Share on other sites More sharing options...
nipper Posted February 15, 2009 Share Posted February 15, 2009 Yes its the same switch. Check the condition of the cable. I think what this means is that there may be somethig wrong with the switch overall, as oposed to the inhibitor switch (positions P and N) itself. But dont quote me on that. Clear the code and see if it comes back. nipper Quote Link to comment Share on other sites More sharing options...
bdecriscio Posted February 15, 2009 Author Share Posted February 15, 2009 Thanks, Nipper, There's an interesting tip on End wrench in the archives regarding the exact issue for 1999 Outbacks like mine, cel and stored code for PO705 >insider info Code P0705, 1999 Legacy If you find a combination of the MIL on and Code P0705 stored in memory, proceed as follows: 1. Open all inhibitor switch circuit connections to be sure the contacts are clean and dry. 2. Plug those connections back together and make sure they are secure. 3. Insure that both the inhibitor switch and the shifter cable are properly adjusted. If you've found no problems so far, the fault is probably inside the TCU (Transmission Control Unit), so replace it. 5. I'm not sure how to adjust shifter cable but I'll do that next. Interesting that the next step is replace TCU rather than the switch itself. By the way, you gave me advice regarding my extreme shifting tranny a while back and cleaning the TPS did the trick(knock on wood) Thanks again, Bob Quote Link to comment Share on other sites More sharing options...
nipper Posted February 15, 2009 Share Posted February 15, 2009 Again an educated guess. The Inhibtor switch failure may be a problem with just P and N (dirty or burned contacts ect in just those two postions). The Code your seeing i most likely a probablme being picked up by ALL positions in the switch, like partial contact, or the switch contacts moving around, or noise in the signal. All of these can be caused by a loose cable or dirty and poor contacts. Since there is not much in the switch (its just on or off for any given postion), it can only be the cable, wires, or the tcu. nipper Quote Link to comment Share on other sites More sharing options...
