February 15, 200917 yr my suspension died along with my axle and brakes on one side, put my car on blocks and decided whilst i was waiting for my parts to change my 10k old oil, changed it marvelled it bye bye tick.... then a nice slow stream of coolant pours down fron dead center front of my motor... water pump ??? is that the best bet?
February 16, 200917 yr or it could be the hose that goes from the top of the block to the intake...............or the hose that goes to the heater core Jeff
February 16, 200917 yr check the hose that gose to the botom of the carb onthe intake i had that go out several times due to its location its a *************** to change
February 16, 200917 yr That little trim to fit hose is $5.49 at NAPA, fits many v-8 fords. On my loyale it's pretty easy to see at the back of the spfi.
