March 8, 200917 yr What other Subaru seats will fit in my 1987 DL 4x4 Wagon? All I have found is Legacy seats will, any others that bolt in easy? I only am concerned about front seats as they need replacement, especially the drivers, and I keep the rear folded down most of the time. Oh, and is there anybody in western Washington that wants to sell or give me some seats ?
March 8, 200917 yr I heard the GL seats have more padding then the DL Ones. Cummon go for custom matching front and rear seats.
March 8, 200917 yr Author I heard the GL seats have more padding then the DL Ones. Cummon go for custom matching front and rear seats. That wouldn't surprise me, kinda like a pullout sofa bed compared to a real bed. Im getting really sick of the metal bar going accross my lower back in my old wore out drivers seat and the plastic trashbag cover I had to put on the bottem because someones f%ing cat snuck into my garage and used the seat pad as a toilet.
March 8, 200917 yr Pretty much any seat will fit with minimal modifications. If you are unwilling or unable to modify the mounting rails then stick to DL or GL seats.
March 8, 200917 yr I have a pair of 87 Wagon seats, and a pair of 90 Loyale. The 87's need a good scrubbing, the 90's are clean but the driver butt padding has just started to crush down - still better than metal bars and garbage bags. XT seats might fit with a minimum hassle, it wasn't too hard to get them into my 90 Loyale RS, inside rear needed a bushing and a longer bolt, outside rear an 85mm long bolt and a spacer. I have seen box tubing and used a piece of aluminum tubing myself. If you go that route I can take a pic to show you.
March 8, 200917 yr Author XT seats might fit with a minimum hassle, it wasn't too hard to get them into my 90 Loyale RS, inside rear needed a bushing and a longer bolt, outside rear an 85mm long bolt and a spacer. I have seen box tubing and used a piece of aluminum tubing myself. If you go that route I can take a pic to show you. Yeah, if you could take some pics of this for me that would be great.
March 9, 200917 yr take the rails off your seats and slap them on xt seats and bam sweet seats in your dl!
March 9, 200917 yr after 20 years I couldn't get the #4 (?) rail screws to budge off the ea82 seats and it was actually easier to just use the xt track with the long bolts... whichever is easiest, I'm sure both ways work
March 9, 200917 yr I am going to give JDM Legacy GT seats a shot in my GL-10. They look alot like the seats in the '02 USDM WRXs. They are alot moe comfortable and have ALOT more bolstering than the OEM GL-10 seats. Patrick
