March 12, 200917 yr Has anyone done the outback lift and kept the OBS Springs, how much lift without using outback springs, What is the difference?? At least one back strut is shot, might as well upgrade if im gonna do the work. thanks in advance italo Edited March 13, 200917 yr by croak
March 13, 200917 yr Author is there a diference in lift between, using outback struts and springs, or outback struts with the original outback sport springs?
March 13, 200917 yr Ah ok. Outback spring rates are based on the Legacy, outback sport based on the imprezza. One car is much heavier then the other. I would stick with same weight class, There may even be physical size differnces. nipper
