1989 subaru gl 10 vent visor?
Where can I find a vent visor to fit the front window ofmy 89 suby gl 10 turbo? Dealership said it would have to be aftermarket... Any thoughts?
Try a aftermarket truck shop - one that sells bedliners, nerf bars etc
brands wound be auto ventshade (AVS) or weathershield but those shops have access to databases for cars as well as pickups
You need a complete window frame to install a vent visor.
How do you expect to attach it?
I'm sorry, but this is not correct. The 1995 Subaru Legacy that I just junked had vent visors and it didn't have window frames. It(the ventvisor) attaches with small metal clips that are mounted between the A pillar and the weatherseal. The bottom portion has small screw holes(comes with screws) that the bottom portion attaches to. Double-sided tape secures the upper portion to the body of the vehicle and creates a water tight seal so that water can't seep through and sneak attack you(Drip, Drip....what the?:eek:) while you have your windows cracked. I hope that that clarifies this.
-Patrick
-Patrick
Any idea if the leggy's would fit a GL? I know they're both frameless, but could be different shape/profile? It's a little wet here, so I need some...even if custom!
It is possible that they could fit, but how well the fit would be is my chief concern.
  • 2 years later...
