EA81/EA82 Higway RPMS Question
What RPMS does a 4 speed d/r EA81 run at:
60 MPH:
65 MPH:
70 MPH:
75 MPH:
What is the redline of and EA81?
What RPMS does a 5 speed s/r EA82 run at:
60 MPH:
65 MPH:
70 MPH:
75 MPH:
What is the redline of and EA82?
If you had a choice which car would you take on a trip from Western Washington to Southeastern Wyoming, assuming they both are in about the same average good condition and both are carbed and both have an equal amout of "stuff" in them, which would you take?
What no 5 speed ea81 rpms? I got a 2wd and it will cruise at 3000rpms at 75.
They both have the same final drive ratios, and similar high gear ratios. I bet you are also running close to the same size tires on both cars. The '83 and up 4spd D/R has a slightly taller 4th than the 5 spds 5th gear. So this may not really be a factor in your decision. The EA82 might be a little more comfortable and have a little more room for your stuff.
Assuming 185-70-13 tire size 83-89 4spd d/r 3.9 final drive
3rd gear high 60 mph=4045 70 mph=4720 80 mph=5393 90 mph=6068
4th gear low 60 mph=3812 70 mph=4448 80 mph=5083 90 mph=5718
4th gear high 60 mph=2608 70 mph=3042 80 mph=3477 90 mph=3911
Assuming 185-70-13 tire size, 85-89 5 spd d/r 3/9 final drive
3rd gear high 60 mph=4632 70 mph= 5404
4th gear low 60 mph=5247
4th gear high 60 mph=3296 70 mph=3845 80 mph=4345 90 mph=4944
5th gear low 60 mph=4211 70 mph=4912 80 mph=5614
5th gear high 60 mph=2645 70 mph=3086 80 mph=3526 90 mph=3967
send me a PM w/your email and I can send you the excel sheet that calculates RPM w/the gears.
BW
