March 24, 200917 yr Ok so I've already changed the plugs, gapped to .040, and it's still stuttering, It's the EA82T In first it pulls hard, 2nd it kinda starts to stutter, 3rd, 4th, and 5th it stutters bad. What causes it to stutter? Would wires, and cap and rotor possibly fix that?
March 24, 200917 yr No codes present? Check the simple stuff first. Your cap + rotor, plug wires, and timing could cause it. I dont know if the turbo units have the same test connector setup as the SPFI, but if it is you want to make sure that they are unplugged. Fuel filter, fuel pump/pressure, throttle position sensor output.
March 24, 200917 yr Get new tune up stuff, make sure you only use NGK plugs. Then check the timing. Make sure before you check, to connect the green plug under the dash/steering column. Then disconnect when done. Timing should be 25deg/800rpm.
March 29, 200917 yr A lil search goes a long way... Code check: care of USRM http://www.ultimatesubaru.org/forum/showthread.php?t=49918 This was in there too looked like some reading you might enjoy. http://www.ultimatesubaru.org/forum/showthread.php?t=79393
March 29, 200917 yr If you bought this from the guy with the 3 rx turbos, call him back and and ask him whats wrong with it, he will know thats probably why he sold it.... could save you alot of time....
