March 28, 200917 yr I just need some pictures of the area around the carb with the air box off, my hoses got disconnected and i cant get them right. Its the hoses on the left side(choke hoses) of the engine if you are at the front.
March 28, 200917 yr Author Stickers dont do me any good an actual photo showing me where they go exactly would be better. Here are some pictures that are ok, but i need more help.
March 28, 200917 yr do you have a large aluminum chunk infront of manifold below carb with many hoses connected? if so, I have many high quality pics available, 10mp will post pics later if needed
March 28, 200917 yr Stickers dont do me any good an actual photo showing me where they go exactly would be better. C'mon. it is a diagram. You are just being intimidated. look at it. it IS a picture of the enigne, and shows you what you are asking. Use it. Get better lighting for your pictiures
March 28, 200917 yr Author I found the diagram and it was a good one and easy to understand. I need to fine tune my timing which shouldn't be too bad. I will get some pictures of the diagram and post them here for future reference.
