To light w/o overheating
Well I am finally getting around to mounting these d@mn 7" HIDs I bought a long time ago for my loyale.
I plan on mounting them on the top of the bumper like in these pics.
How adversely will these effect my engine temp?
Thanks guys,
S
You should be fine.
The lamps don't appear to block too much airflow.
Not to mention you have a lot of flow coming up from under the car.
Just enjoy your new lights and keep an eye on that temp gauge!
Twitch
meh, if you've still got a working fan, you could put a dozen lights up there and not really have an issue (with airflow anyway.....your alternator would probably implode though....)
I recently installed a new (or rather re-manf) alternator and with these lights only pulling 35watts each I dont think it should be too much of a electrical issue.
Well I guess if no one on here can find a problem, I'll bolt these up tomorrow! :banana:
They barely block the grill, you'll be fine. They may screw up the beam pattern from your headlights though.
