4wd trouble
when I put my 4wd low in gear on dry pavement it shakes furiously when it drives what do you think is the problem I need to fix it. The wagon has a 4inch lift maybe the driveline has to much stress?
Sounds like things are binding up. Don't put it in 4wd on pavement.
Maybe its because you are not supposed to use 4wd on dry pavement??? :rolleyes:
Hey Michael,
Which wagon is shaking, the one with the welded rear or the new one?
You got a tire or two worn more than the others? If I put mine in 4wd on pavement it will bind and hop a little. I also have missmatched tires. Same size, different treads. No problem in the dirt. What happens when you use 4wd in the dirt?
