June 15, 200916 yr ok i have an 88 gl wagon and just bought a 93 legacy wagon im going to do a ej swap and want to put the legacy suspenion on the gl aswell and keep my d/r trans what other parts will i need that i cant get from the legacy oh and my gl has a sjr 4 in lift on it already if that makes a diffrence
June 15, 200916 yr *most* of the suspension bits you need are from an XT6. The legacy front struts will work and possibly some of the brake bits - maybe the axles. The knucles and the entire rear end will have to come from an XT6 to swap the GL over to 5 lug. If it's got a lift already - why aren't you going to chevy 6 lug? 5 lug doesn't have the proper wheel selection for wheeling. GD
June 17, 200916 yr Author i have the chev 6 lug already i just wanted the better brakes was the main reason for wanting to switch to the 5 lug setup thanx for the info i guess ill need to keep my eye out for an xt6
