June 20, 200916 yr At the risk of sounding redundant, I am hoping that some one would be able to direct me on how to properly preform the D-CHECK PROCEDURE. I currently am with out a pdf reader on this pc and it would be most helpful to learn this procedure so I may properly Diag my 93 loyale spfi.
June 20, 200916 yr You REALLY need to print out the entire PDF. Seriously there's a TON more to it that I don't have time to bring over as images in order to post here. I'll give you the procedure so you have an idea as to what you need to do, but I can't copy the whole thing here. GD
January 5, 201214 yr The link for the PDF no longer works... anybody have a better link or description how to do D-check?
January 5, 201214 yr Author The link for the PDF no longer works... anybody have a better link or description how to do D-check? I am also looking for the proper "D-Check" Proceedure. Hopefully someone has the up dated link so we can access it. I reaaly could use it. My 1992.5 EA82 is getting up there in mileage (117,588)...not to mention years....and could really use some proper servive. Thank You In Advance.....
