June 23, 200916 yr in the crash, the timing case was bumped knocked the belt out. so ill fix that......until the ring with the marks on it came off the sprocket. i was tring to bend out a small dent and now what? it was goiing to be sooo simple... thanks
June 23, 200916 yr Never mind, I thought you said Loyale. Might want to ask in the newer generation forum.
June 23, 200916 yr Which ring ? and dont say the one with the timing marks Where is it on the engine? The only things i can think of, well, that has to be one hell of a dent in the front end. nipper
June 23, 200916 yr Are you talking about the front of the engine where the crankshaft pulley is? Is it situated directly behind the pulley and goes up to 20"? I'm not too sure that is essential. I completely rebuilt the top end of my 2.2 and I never needed to use those marks. Twitch
