July 3, 200916 yr Hi, Message board looks good! I'm hoping someone can steer me to a source for replacement supports for the rear lift door on a 2003 Forester. Online searches for hatch supports, hatch struts etc. turn up replacements by Stabilus or others that fit various Subaru models, but not the Forester. Info greatl appreciated, Thanks, SN
July 3, 200916 yr I realize you're trying to be cute but I have no idea of where Morris is. Please update your profile with a meaningful location. That said I've had good luck with getting replacements for other off beat cars from Advance Auto. But since I don't know where you are at I don't know if you may have Advance's near you.
July 3, 200916 yr Author Thanks, Advance shows "universal" supports, so I will try them. Hard to see why a 2003 Forester would be "offbeat," maybe there hasn't been demand yet. BTW - Your "realizing" is way off the mark. I simply registered, and wrongly assumed that the state that I entered would be visible. Why not just suggest that a guy ought to put more info in his profile... instead of getting "cute" on me?
July 4, 200916 yr It just helps sometimes if we know where folks are at. Lots of little towns with the same name exist in several states. Then there are the great names like "tri-state area", "in the woods", "up the creek", whatever. Not meaningful at all. Folks here are very helpful. It helps to know where folks are at to offer assistance personally, etc. I've had pretty good luck with the struts from Advance. Can't recall the name but they come in a Grey Sleeve. I'm talking about on other makes of cars. I've never needed them (that I didn't already have) on a Suby.
July 4, 200916 yr 63269SA001--STAY, REAR GATE FOR RIGHT SIDE 2003-2008 FORESTER 63269SA011--STAY, REAR GATE FOR LEFT drivers side 2003-2008 FORESTER Give those numbers a try.
July 5, 200916 yr Author Thanks, found some at subarupartsforyou.com at $49 ea. was hoping for under $30 from aftermarket - I'll check to see how much they are from the dealer.
July 6, 200916 yr Thanks, found some at subarupartsforyou.com at $49 ea. was hoping for under $30 from aftermarket - I'll check to see how much they are from the dealer.The trouble with aftermarket ones is that sometimes they don't provide the range of motion that the OEM ones do. I'm not saying to just straight up buy OEM ones, but it is something worth considering. Have you tried rockauto.com?
July 6, 200916 yr Author The trouble with aftermarket ones is that sometimes they don't provide the range of motion that the OEM ones do. I'm not saying to just straight up buy OEM ones, but it is something worth considering. Have you tried rockauto.com? No dice, in spite of their declaration "All the parts your car will ever need" Thanks
