July 23, 200916 yr Hello everyone and good day. I know this is a dreadful question that has probably been asked before but here i go any how. What is the difference between a ea82 P\T D\R and a F\T once the P\T has been put into 4wd? Does the P\T have a lower "low range" and which one would be better for an offroad rig? Thanks Jordan
July 23, 200916 yr The chart is here in about 40 different posts, but yes the P/T has a lower low range, and it's FWD when it's not locked in. The AWD one is always putting power to the rear wheels, typically has a 3.70 gear ratio, but is otherwise the same.
July 23, 200916 yr full-time doesn't have a 2WD setting. in a 5-speed, it has a lockable differential. un-locked, they're pretty mediocre. locked, they function identically to the PT4WD setup. the PT4WD trans has a lower lo-range (1.596:1 vs 1.196:1), AND a lower diff ratio (3.9 vs 3.7). so for offroading, the PT4WD is better. also, FT4WD D/Rs are quite rare (only in the RX), whereas PT4WD D/Rs are quite common. EDIT: oh yea...the chart: http://www.ultimatesubaru.org/forum/showthread.php?t=84798 the only time I would recommend the FT4WD, is in something with a 2.2 swap. you'll have the torque to keep the tires spinning, so for 99% of what most people would be using them for, you won't need the extra gearing. and you'll have the extra traction for the street (FWD + EJ22 torque + EA82 suspension = wheelspin!)
