weber tuning
I just installed my new weber on my '85 wagon and it's not running right. When i start it, it will rev up to 2500 rpm and then die in about 5 seconds. what did i do wrong?
there is a return spring and the throttle moves freely
is there a really good write up on the process?
these are the ones i found but didn't help
http://www.ultimatesubaru.org/forum/showthread.php?t=74206
http://www.ultimatesubaru.org/forum/showthread.php?t=49931
this one would have, but i cant see the pictures
Edited by Markus56
If you play with the gas will it stay running? Honestly something sounds more out of wack then just throttle linkage. Have you also checked for vacuum leaks? My check list would be:
Choke...adjusted?
Vacuum leaks
Something plugged up inside the carb
Without knowing more thats all i got for you.
one eye is headed over sometime today, so hopefully he can get this figured out.
There shouldn't be anything wrong with it, it was professionally rebuilt by a carburetor guru. It might be something as silly as a vacuum hose not plugged.
The adaptor plate is cracked..............................I think that is the problem
Jeff
