hebrewhammer Posted August 17, 2009 Share Posted August 17, 2009 95 impreza 1.8l 5 speed awd. just installed a new tranny. started her up and a very loud grindingish noise came from the engine bay. detached accesory belt and tried again. same noise. the noise is the same clutch in and out. it is linked to RPM's Took the starter out to see if i could see wear from possible after start engagement....it look fine and the motion of the gear poping into position seemed smooth I'm thinking i somehow crushed the pilot bearing upon install. any thoughts here gentlemen....? or could be that a clip fell off the throuwout bearing? these are my best guesses. someone please tell me i'm wrong. Quote Link to comment Share on other sites More sharing options...
EVOthis Posted August 17, 2009 Share Posted August 17, 2009 Ive done both of the things you mentioned before..Its quite easy to do especially when your installing a tranny in these cars without the use of a lift.....Those clips are a PITA. Does the car move at all when you put it in gear and let off the clutch? I will say this..you would have never gotten the bellhousing to engine bolts/nuts in/on if you didnt get the input shaft in the pilot bearing.....Im assuming youve used a new pilot bearing/clutch kit here? Quote Link to comment Share on other sites More sharing options...
hebrewhammer Posted August 17, 2009 Author Share Posted August 17, 2009 just installed a new clutch 1000 miles ago so the pilot bearing and throwout are new. I guess i should have used new clips!!!!!!!!!. havn't tried to move it but if it moves am i good....? anyone else second the clip theory..... did you have to pull the whole tranny again or could you jimmy your way in there.... looks like another long weekend:mad: GOD DAM IT! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 18, 2009 Share Posted August 18, 2009 Did you bother to spin the input shaft on your "new" transmission before installing it? Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted August 18, 2009 Share Posted August 18, 2009 Did you put oil in the new transmission? Quote Link to comment Share on other sites More sharing options...
hebrewhammer Posted August 18, 2009 Author Share Posted August 18, 2009 yes i did spin the tranny and it felt fine. yes i did put oil in it.... NOT that much of a NEWB! looks like some tranny fun for me! Quote Link to comment Share on other sites More sharing options...
lostinthe202 Posted August 19, 2009 Share Posted August 19, 2009 I thought that if the clips fell off that would let your TO bearing rattle around and so make a helluva racket with the clutch out, but as soon as you put tension on it, it would shut up. Is this not the case? When you say it's linked to RPM, what do you mean? Does it get louder the faster the engine spins? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 19, 2009 Share Posted August 19, 2009 Did you install the cover plate at the bottom of the engine? I ask because that cover plate can become bent and rub against the Flywheel. Quote Link to comment Share on other sites More sharing options...
