bluto5 Posted December 11, 2012 Share Posted December 11, 2012 (edited) Hi all, I have an impreza that has been ej25d swapped and the time has come to do the head gaskets. So I am gathering my gaskets and discover I need to sort out the valve cover particulars. I didn't know previously that there were changes in this area. So, question is.. With no vin from the original vehicle, how do I determine which (of the 4 types?) of valve cover gaskets I need? Any insight? Thanks, Sam Edited December 11, 2012 by bluto5 Quote Link to comment Share on other sites More sharing options...
987687 Posted December 11, 2012 Share Posted December 11, 2012 Post a picture of the gasket that came out, the valve cover, and/or the head. Chances are someone on here who works on a lot of those will know which year it is. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 11, 2012 Share Posted December 11, 2012 there are only 2 options for the EJ25D (1996-1998 and 99 Legacy/Outbacks) looking at the spark plug holes and spark plug hole gaskets will confirm. notice the difference in the spark plug gaskets between the following two links, these are the two styles: http://www.ebay.com/itm/98-99-Subaru-EJ25-DOHC-2-5L-AISIN-Water-Pump-Timing-Belt-Valve-Cover-Kit-/360422091684 and here: http://www.ebay.com/itm/2-5L-FORESTER-LEGACY-IMPREZA-EJ25-VALVE-COVER-GASKET-/200566575313 figure out which is yours and correlate to the appropriate motor, year, etc and you'll figure it out. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 11, 2012 Share Posted December 11, 2012 i have a set of valve cover gaskets for an EJ25D that i likely won't need any time soon from Subaru. PM or email me if you want to buy them. i can verify which style if you're intersted. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted December 11, 2012 Share Posted December 11, 2012 95-96 97-98 98-99 one is stamped twinn cam others are blank covers after 97 no hydrolic lifter engines Quote Link to comment Share on other sites More sharing options...
bluto5 Posted December 11, 2012 Author Share Posted December 11, 2012 Thanks for the quick replies. I hadn't seen the square plug hole before. So '99 ej25d had those.. Do they fall into the grey area of phase 2 ej25d that I have heard about? Are the 2.5rs ej25d square plug also? Just curious here. I was aware of the hyd lifter heads. So my confusion started with azones website, (98 subaru outback) 4 felpro listings based on vin. What I failed to notice befor was that it was only two part numbers. That narrows things down a little bit. The pics show both kits with the oval plug hole but I wonder if one is the square kit. My heads have the oval plug holes. Sounds like all of these gasket kits should be the same..? Thanks again for the help. Sam Quote Link to comment Share on other sites More sharing options...
