Midwst Posted June 25, 2005 Share Posted June 25, 2005 Question. Does it harm the engine if a person overfills the engine oil by 1 qt? No, I didn't do it, just asking. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 25, 2005 Share Posted June 25, 2005 It's not good.....however I don't know if it will damage the engine.... Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted June 25, 2005 Share Posted June 25, 2005 I seriously doubt it. Quote Link to comment Share on other sites More sharing options...
Commuter Posted June 25, 2005 Share Posted June 25, 2005 Generally, there should be enough "buffer" room in an engine to handle 1 qt. At some point, overfilling will result in the crank striking the suface of the oil. When that happens, the oil is whipped into a foam. One gets air bubbles in the oil. Oil with air bubbles does not provide the same lubrication to the engine. And so on. It is not a case of 0.95 qt is fine, and 1.05 qt will destroy your engine. If you think about going up and down hills, around corners, etc, you can appreciate that at some point, an overfill will result in occasional striking of the oil surface by the crankshaft. It will get progressively worse at higher oil levels (more overfill) from that point on. At what point this happens in a Subaru engine, or any make of engine, I don't know. Commuter Quote Link to comment Share on other sites More sharing options...
Scottbaru Posted June 25, 2005 Share Posted June 25, 2005 What would be the effect of oil flowing into the cylinder beneath the piston, like if the car is tipped sideways on a steep hill or slides into a ditch? I've tossed around some airplanes with boxer engines, never really thought about this. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 25, 2005 Share Posted June 25, 2005 Look at these pics. You're going to really have to over fill it to get the crank whipping the oil http://www.main.experiencetherave.com:8080/subaru/images/ej22t/2/ Quote Link to comment Share on other sites More sharing options...
jib Posted June 27, 2005 Share Posted June 27, 2005 Depending on the location of the front and rear seals in relation to the oil level, you could cause some problems with leakage. I don't know if the Subie is subject to it, but my rule is to keep the oil within 1/4 quart of the mark. That's a half quart to play with and should be easy to do. The subies have sufficient oil capicity for the system. There is no reason to overfill. Jack Quote Link to comment Share on other sites More sharing options...
Andyjo Posted June 27, 2005 Share Posted June 27, 2005 your dip stick may come blasting out when you start up her up.. if you have THAT much in there... very humorous... if it doesn't happen to you :cool: Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted June 27, 2005 Share Posted June 27, 2005 It's easy enough to undo the oil pan drain plug for 2 seconds. No more over fill! Just a thought... Quote Link to comment Share on other sites More sharing options...
Midwst Posted June 27, 2005 Author Share Posted June 27, 2005 Humerous TRUE story: A man in my apartment complex bought his first car at age 58. He knocked on my door and said that the car was making noise. Would I come look? I discovered it was quite low on oil. I advised him to "top it off". The next day he knocked on my door again. The car would not start. I asked him if he had added the oil. He said Yes. I went down to check it out. I pulled the dip stick. The first 18" were covered with oil. I opened the oil filler cap. Engine oil was up to the top of the valve covers. I tried not to laugh. "yep, looks like you topped it off pretty good! How many quarts did it take you?" Answer: "10" Quote Link to comment Share on other sites More sharing options...
nurseman Posted June 28, 2005 Share Posted June 28, 2005 i have a 05 baja turbo and recently traded my 02 impreza rs both manuals state oil capcity of 4.1qt. but i find i end up putting in 5qts to make my stick read to the full line and sometimes it may be a little over that and i never had a problem with my engine ever. when i put 4 qts in the stick reads low i dont know the reason when the manual states 4.1 to fill. Quote Link to comment Share on other sites More sharing options...
