got torque bind....
7 replies to this topic
#1 bgambino
bgambino
    Subaru Nut
  • 710 posts
  • new york
Posted 15 September 2009 - 07:16 PM
newly acquired 93 legacy automatic
shutters good in toght circle both left and right turns
put fuse in and no shutter!
one thing i looked for tonight was the AT light on the dash with the key on (I read that there is supposed to be one right??)...there was none
I will change the fluid a few times but I should put a bulb in...I did some research here and I think a flashing AT light could mean the duty c solenoid is bad...is that correct? (whats involved in changing it)
All guidance welcomed (I don't want to learn how to take down the rear part of the tranny:-\)
Also it had a rythmic thumping (not really a thump but a growl...sort of)...rythmic with tire rotation...driving straight and turning wheel to left and noise is heard...turn wheel even just a little to right and quiets down mostly
I would guess wheel bearing rather than cv joint (no clicking anytime)...?
#2 Log1call
Log1call
    Eat, Live, Breath Subaru
  • 280 posts
  • New Zealand
Posted 15 September 2009 - 08:47 PM
Sounds like wheel bearing to me from that discription.
Jack up the back end(put it on blocks), then grab the wheel at top and bottom centre and the alternatively push in with one hand and pull out with the other. I there is any play the bearing is buggered(as we say here in New Zealand). Give it a spin as well and see if it sounds noisy to confirm.
#3 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,013 posts
  • East Coast
Posted 16 September 2009 - 06:05 AM
axles could be shot too from the torque bind, it stresses them. it would be the inner joints that are hosed.
TONS of torque bind info here.
change the fluid a few times and try to put some miles on it.
there's an LSD additive (GM is recommended) to get rid of it if the fluid change alone doesn't.
it's all covered here, spend some time reading.
#4 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 16 September 2009 - 08:13 AM
if the fuse cures the torque bind, then your duty c is fine. but if you have to open it up to correct the problem, replacing it is only another 75 - 85$.
#5 bgambino
bgambino
    Subaru Nut
  • 710 posts
  • new york
Posted 16 September 2009 - 06:02 PM
thanks guys
Anyone know if ther is definitely a AT light on the dash?
I don't have the owners manual to be able to look...and I used a flashlite to see if any of the idiot lites were for the AT, but the flashlite did not illuminate it so as to tell what they are
#6 Log1call
Log1call
  • 280 posts
  • New Zealand
Posted 16 September 2009 - 07:44 PM
Every legacy I have seen has had the light. It's down the bottom of the display in the centre. There are usually two of them side-by-side.
#7 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 17 September 2009 - 06:13 AM
i think for the 90 - 94 auto trans the warning light was the blinking "power" light. so you may not have the "AT TEMP" light on your dash.
#8 idosubaru
idosubaru
  • 24,013 posts
  • East Coast
Posted 17 September 2009 - 07:20 AM
yes, you have a light on the dash. you would not miss 16 flashes at start up, so that tells me it's not flashing.
we already know it shouldn't be flashing anyway. the issue goes away with the FWD fuse. that means the Duty C solenoid is working properly and you're not going to have a flashing light due to torque bind.
