Brake fluid & Oil together at last
7 replies to this topic
#1 MaroonDuneDoom
MaroonDuneDoom
    Stick It To The Man!!!
  • 604 posts
  • Casper,Wy
Posted 05 February 2004 - 11:48 AM
this guy and i were talking subaru when he brought up the subject of oil leaks. He told me that the next time I add oil to my ea82 that i should pour in a couple tablespoons of brake fluid. he told me that it will expand the gaskets and help my oil leak subside a little. Is this true?
#2 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 05 February 2004 - 12:07 PM
brake Fluid?:eek:
Dump some into his car first and run it around for a few hundred miles..
Brake fluid is nasty stuff.. I wouldn't do it.. but maybe someone here knows better than me..
#3 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 05 February 2004 - 12:42 PM
ALWAYS be sceptical of miracle cures. Some are true, some are false. The false ones can sometimes make things worse or cause other, new and more expensive problems.
I say, whatever oil you choose: Leave it alone. The company producing it has weighted up a number of factors and settled for the best compromise.
If the oil isn't doing what you want, try another type of oil, don't put additives in it!
Leaks are leaks, and replacing the seals is the way to cure the them.
#4 junkyardgabe
junkyardgabe
    WRX Goal Accomplished!
  • 558 posts
  • Lisbon Falls
Posted 05 February 2004 - 12:53 PM
that and brake fluid usaully only works with rubber seals and gaskets and is a very temporary it will only last a week or so
most people usually do that trick in the tranny's its just like carb cleaner in your your tranny if you have a slipping tranny and you need a temporary fix these are only temporary fixs and shouldn't be used on a regular basis
#5 MaroonDuneDoom
MaroonDuneDoom
  • 604 posts
  • Casper,Wy
Posted 05 February 2004 - 01:41 PM
so....it's partially true. looks like this guy isn't as full of $hit as he seems to be.
don't worry, i'm not gonna go dump brake fluid in my engine.
#6 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 05 February 2004 - 02:38 PM
thats crazy. silicone or hydrolic dot 5 or 3?
if you mix 5with3 it will ruin you seals, makes the rubber turn to goo. if its just hydrolic brake fluid, it should just thin you oil out a bit. sounds like a crack head idea.
#7 MaroonDuneDoom
MaroonDuneDoom
  • 604 posts
  • Casper,Wy
Posted 06 February 2004 - 02:33 AM
yup. definitely crackhead idea. whats funny is the fact that the guy actually is a crackhead. not rock cocaine but that goddamn meth. he's got a thousand+ ideas just like it.
#8 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 06 February 2004 - 02:43 AM
sounds like used car dealer tricks, not actual repairs
