jumping into 4wd
14 replies to this topic
#1 corvette6698512
corvette6698512
    USMB is life!
  • 128 posts
  • Tumwater, Wa
Posted 23 December 2009 - 03:20 AM
My '83 GL just randomly pops itself into 4wd while driving. Its not like its rarely either. Once its in 4wd, its hard to put back into 2wd also. Is this a common thing on the older GL's? Its a 4 speed. I'm planning on doing a 5 speed swap, but like everyone else, no money to cover the cost of that quite yet. I probably wont have the money for a while, so I want to get this figured out. Thanks!
#2 rxleone
rxleone
    Subaru Fanatic!
  • 558 posts
  • Christchurch, New Zealand
Posted 23 December 2009 - 07:37 PM
I've never heard or seen that happening, and me and my brother have both owned a few ea81s (mainly ea82s though :D)
My advice would be to swap out the 5spd ASAP. (Pretty useless I know :) )
#3 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 24 December 2009 - 03:24 AM
My guess would be bad motor and tranny mounts. Those would let things flop around enough to pop it into to 4WD.
Just my .02
#4 Gloyale
Gloyale
    It's a sickness
  • 10,179 posts
  • Corvallis, OR PNW
Posted 24 December 2009 - 12:06 PM
Just my .02
Second that.
And also the lever might be adjusted too tight.
#5 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,199 posts
  • Portland
Posted 24 December 2009 - 01:04 PM
Yep - very likely bad tranny mounts and don't overlook the pitching stopper - that negates exactly the kind of movement that would cause your problem.
#6 corvette6698512
corvette6698512
    USMB is life!
  • 128 posts
  • Tumwater, Wa
Posted 25 December 2009 - 04:56 AM
Pitching stopper? Where would that be? It does need new trans mounts though.
#7 TomRhere
TomRhere
  • 4,600 posts
Posted 25 December 2009 - 05:23 AM
It's just left of center where the engine/trans bolts together and runs back under the spare tire mount.
#8 wysei82
wysei82
    New User
  • PipPip
  • 14 posts
  • rochester
Posted 26 December 2009 - 08:18 PM
Maybe she just thinks she's an AWD
#9 corvette6698512
corvette6698512
    USMB is life!
  • 128 posts
  • Tumwater, Wa
Posted 28 December 2009 - 11:11 PM
So i was messing with the 4wd and it got stuck in 4 low. The shifter pushed down but didnt put it in 2wd, so i climbed under the car and pulled the rod into 2wd. Turns out the nut for the shift linkage came off. So now everything fells way better, no more slop and it hasn't popped into 4wd. The 4wd light stays on though(even if its in 2wd). Where is the switch for the 4wd light located?
#10 corvette6698512
corvette6698512
    USMB is life!
  • 128 posts
  • Tumwater, Wa
Posted 01 January 2010 - 08:57 PM
Nobody knows? Maybe a way to adjust the 4wd shift bar so the shifter is pushed down further when in 2wd?
#11 corvette6698512
corvette6698512
    USMB is life!
  • 128 posts
  • Tumwater, Wa
Posted 05 January 2010 - 08:38 PM
Extended the 4wd shift rod. Easy fix.
#12 MAD MAX
MAD MAX
    USMB Regular
  • PipPipPip
  • 30 posts
  • Olympia
Posted 05 January 2010 - 09:06 PM
Glad it worked for you :)
#13 eulogious
eulogious
    Inspiring Subaneer
  • 1,090 posts
  • Olympia, WA
Posted 06 January 2010 - 04:18 AM
Don't you love it when the easiest solution is the best? Glad you got it working! Now just don't go running it into stuff and you should be all good! :lol:
#14 bertaru
bertaru
    New User
  • Pip
  • 5 posts
  • Portland
Posted 11 May 2010 - 01:00 AM
do you have a actual 4WD shifter or is it one of those vacuum operated push buttons on the shifter? if its a push button, check the switch and the vacuum solenoids. having a similar issue but its really intermittent.
#15 GeneralDisorder
GeneralDisorder
  • 21,199 posts
  • Portland
Posted 11 May 2010 - 12:01 PM
1: He already solved the problem.
2. EA81's and older (that's all models through '84) are all rod-shifted. They did not make a push-button except for the automatic's.
