Toyota transformation
13 replies to this topic
#1 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 05 January 2010 - 10:30 AM
Well, I have started the change from street/trail truck to trail truck.
http://www.ultimates...&pictureid=1999
I installed an Isuzu rear disc brake read axle. Replaced the broken front axle. I got new poly bushing for the rear springs. The welded diff goes back in the rear. An ARB unit goes into the front.
I have a flatbed for it. I will be dove-tailing it starting at the rear tires. And removing about 4-8" off the exsisting frame. My brother has been starting a fab shop and he has done an exo on his Cherokee. Mine is next, along with skidders and a re-done roll bar for the bed.
Line lock and a new proportioning valve will finish of the brake system. Also moving the shock mounts to get a couple inches more travel.
Should work out well. Then just need dual cases and high steer to finish it off.
#2 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 05 January 2010 - 11:01 AM
I installed an Isuzu rear axle.
what Ratios are ya runnin
#3 Qman
Qman
  • Moderator
  • 11,119 posts
  • Sumner
Posted 05 January 2010 - 12:25 PM
4.30/1 They came from a V-6 auto. The gearing works well and the teeth are big enough not to worry about breaking them. Just need the dual cases now.
#4 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 05 January 2010 - 04:03 PM
Ken if you are on a budget you may want to consider re-gearing your transfercase instead of adding a 2nd. Right now you can get 4.7:1 T-Case gears for $300, but if you do the 2nd case you need the adapter, 2nd case & custom front & rear drivelines... and you should replace your t-case mount as well. When I added it all up, it was nearing $800 for the dual cases.
I run the 4.7:1 gears in my single case and I love it. Its obviously a huge upgrade, and almost as low as the dual cases.
Im curious to know more about the isuzu rear axle. Is it as wide as the 86+ toyota axles or is it narrow like the older toy's?
#5 Qman
Qman
  • Moderator
  • 11,119 posts
  • Sumner
Posted 05 January 2010 - 04:12 PM
I have thought about that as well. We'll see when I get to that point. 4.7 would be a huge upgrade over stock. I haven't done a tape measure verification but it appears to be the same width as my Toy axles. But, it is disc. It does accept the toy third member. I am adapting/merging the Toy and Isuzu brake lines. I like the idea of having line lock instead of cable E-brakes.
#6 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 05 January 2010 - 04:31 PM
Yeah right now i have no e-brake at all. And rear disc's would be a welcome upgrade.
Right now Trail-Gear just offered a rear disc conversion kit that comes with pretty much everything you need (calipers, rotors etc...). My only problem is money.
I also like the idea of single t-case so I can carry spare drivelines and not need to worry about paying for another set of custom drivelines. I can get spare drivelines off craigslist for $40 all day long :)
#7 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 12 January 2010 - 02:31 PM
where?
Edited by Qman, 12 January 2010 - 02:42 PM.
#8 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 12 January 2010 - 05:16 PM
Trail Gear had them on sale when I posted that. I guess their sale is over, cause they are back up to $350.
Still not a bad deal.
#9 kelsomcgath
kelsomcgath
    USMB Regular
  • PipPipPip
  • 61 posts
  • Tumwater, WA
Posted 12 January 2010 - 07:33 PM
Low Range Offroad has them on sale right now for $330
-Kelsey
#10 Qman
Qman
  • Moderator
  • 11,119 posts
  • Sumner
Posted 25 January 2010 - 02:49 PM
So an update...
The Isuzu axle did not accept the toy 3rd. Ended up going with 4.56 gears. ARB rear diff and line locks. A bonus that I had not planned for was now I am using a Detroit instead of a lock-rite in the front. I found a slightly used one off of Craigslist for $300. Couldn't pass it up.
So, now I have better gearing and locked front and rear. Hoping to have enough cash left over to add high steer also.
Hoping to be trail ready in a month or so with the flat bed installed as well.
Edited by Qman, 25 January 2010 - 03:02 PM.
#11 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 25 January 2010 - 10:26 PM
Are you running the stock shafts & birfs up front?
#12 Qman
Qman
  • Moderator
  • 11,119 posts
  • Sumner
Posted 25 January 2010 - 11:24 PM
Oh yeah... I have one set of spares. We'll see how long they last.
#13 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 26 January 2010 - 12:05 AM
Let us know. I cannot afford to upgrade my shafts, so I am just going to carry a set of spares when I lock my front end. And, unless I can find a deal on CL like you, that might be a while.
#14 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 08 February 2010 - 01:02 PM
nice. I just got a set of ebrake cables and lever from a '97 4-runner (floor pull like the soobs) I'm going to try and use when I get some different rear axles... or swap to rear discs...
