Brake Problems.
3 replies to this topic
#1 The Dude Abides
The Dude Abides
    WileE Coyote Super Genius
  • 2,998 posts
  • West Des Moines, IA
Posted 02 August 2010 - 02:53 PM
So after working on my brothers brakes in his cutlass i thought i would check out the tauruses brakes. I didnt half to check far. Both rear brakes rotors are covered in rust. Like they havent been used in quite a while. All the braking is being done up front. Before i dig into this i was wondering if anyone had come across this problem before. Could the calipers be siezed open. Maybe the sliders need greased, or my porpotioning valve is garbage. Any other ideas would be very helpfull.
#2 TheLoyale
    Safariwagon: The Legend
  • 7,079 posts
  • Waukesha, WI
Posted 03 August 2010 - 10:21 AM
Sounds like the piston is just stuck from rust, does he drive this car everyday or has it sat in the yard for a while? Cause even with rust the piston should still be able to move a little (Hydraulics have a lot of pressure ya know) and even if the slider pins rusted and the caliper was stuck to them, the piston should push out enough to still hit the pads.
Another idea is, does it have a hand brake? If so that would be manuel cable type (Not hydraulic) so thats one way to see if fluid is getting to the rear or not. If it grabs then you know somethings fishy with the brake lines.
#3 mudduck
    Subaru Nut
  • 708 posts
  • Asheboro NC
Posted 07 August 2010 - 06:07 PM
Helped a buddy of mine out a couple weeks ago do the brakes on a BroncoII he recently picked up. It had a blown wheel cylinder in the rear which the previous owner fixed be pinching off the rear brake lines.
#4 nipper
    Semi Elite Master of the
  • 18,194 posts
  • Long Island NY
Posted 08 August 2010 - 07:12 PM
Frozen calipers. Slide pins are seized, or the pistons or both. I would see if it is just the sliders, then you may not need to replace calpipers
