Shift Lock System problem
10 replies to this topic
#1 dssenne
dssenne
    USMB Regular
  • PipPipPip
  • 81 posts
  • O'Fallon
Posted 28 September 2011 - 07:38 PM
My FWD '92 Legacy (auto trans.) recently developed a problem where you can't move the selector lever from "P" to any other position unless you press the shift-lock release button. From what I read it's a problem with the "Shift Lock System", but I can't find anything to do about it. It's doing it pretty much every time now. Until I can figure it out/get help/take it somewhere, can I continue to drive it using the release button, or am I destine to get stranded at the worst possible time? Any ideas how I can fix this?
Thanks
#2 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 28 September 2011 - 08:09 PM
Thanks
there is a solenoid that activate when you step on the brake when the car is in park. it withdraws a pin which un-locks the shifter. mine is intermittent. i had it tied down with a rubber band for a while. but i am still a little scared of it.
if you remove the console around the shifter you will see the mechanism. my guess is that a used one would be a good bet, but i don't really know.
i also don't know what the cost new.
#3 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 28 September 2011 - 10:40 PM
When you press the brake pedal and the gear selecter buttom you should hear a relay under the dash click, do you?
The solenoids sometimes get gummed up over the years from that coke that got spilled in there and no one owned up to :)
#4 bheinen74
bheinen74
    Banned
  • Banned
  • Pip
  • 0 posts
  • central Iowa
Posted 28 September 2011 - 11:12 PM
or it could be the beverage of coca cola that got spilled in there.
sounds like a good time to remove the shifter console trims, and see if you can clean the electrical thing ,maybe with some windex.
#5 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 28 September 2011 - 11:14 PM
So your the one who spilled it?
#6 dssenne
dssenne
    USMB Regular
  • PipPipPip
  • 81 posts
  • O'Fallon
Posted 29 September 2011 - 08:33 AM
Thanks, I'll check that out when I get home tonight.
#7 dssenne
dssenne
    USMB Regular
  • PipPipPip
  • 81 posts
  • O'Fallon
Posted 29 September 2011 - 05:31 PM
Yes, I hear a click under the dash. I'll pull the trim around the selector this weekend and check it out.
#8 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 30 September 2011 - 07:43 PM
Yup sounds like the solenoid quit or it is gummed up.
#9 dssenne
dssenne
    USMB Regular
  • PipPipPip
  • 81 posts
  • O'Fallon
Posted 01 October 2011 - 01:43 PM
Today I pulled the console covers to see if the solenoid was gummed up (it seemed fine- not dirty at all).
Now when the selector is out of P, I can move it to the other positions without pressing the grip button. The only exception is that the button has to be pressed to go from N to R.
I did loosen the selector lever (two screws on side) so I could lift the indicator cover up a bit to see the solenoid better. When I did this the grip button came out. But I thought I got it back together correctly.
I know this is a stupid question, but the grip button needs to be pressed in order to be able to move the selector from say, D to N or 3,2,1 doesn't it? I never really tried to do so without pressing it, so I don't know if I screwed it up!
If I did, any suggestions about what to do? I REALLY need to get it back together today!
Thanks
#10 dssenne
dssenne
    USMB Regular
  • PipPipPip
  • 81 posts
  • O'Fallon
Posted 01 October 2011 - 01:50 PM
Thanks
When in doubt read the manual. Sorry for the lame post...
#11 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 01 October 2011 - 04:40 PM
D to N and to D no
revers to neutral to drive no
Neutral to reverse yes
Downshift yes
upshift no.
