Time for upgrades to the Brat
12 replies to this topic
#1 wallaby
wallaby
    USMB Regular
  • 175 posts
  • clarkston,wa
Posted 25 January 2012 - 02:48 PM
Posted Image
before...
Thie is my daily driver Brat, 82 DL single range completly stock except for the weber and a loud exhaust, had it for a few years and driven the hell out of it for not a lot of input,
I have been collecting parts for the required ugrades
- so around thanksgiving it was time i pulled it off the road - the oil was finnally leaking out of EVERY gasket, all 4 front axles boots were torn, tranny was jumping out of gear etc etc.
now it is back to running again with a few minor issues to sort out - exhaust and tranny mounts.
now it has
regasketed engine
complete tune up - plugs,wires, cap ,rotor etc
new OEM t'stat and intake gaskets
one piece radiator(as opposed to the 2 piece one it had before)
"new" exhaust - gutted cat, old 18" cherry bomb, side pipe - needs more modification
new EMPI axles
dual range 5 speed
new lengthened rear driveline
rear disc brakes
new front pads
6 lug hubs
6 lug wheels OEM mazda pickup alloys - perfect offset and the suby caps fit:grin:
fronts are 205/75/14 rears are 245/60/14 -
NO LIFT, NO RUBBING, NO BASHING
i know they are different - about 1/2" in height - thats what was on the wheels and the 245 fit on the back -they look MEAN and i will be careful in 4x4 till i get them all the same
Posted Image
Posted Image
still have some stuff to sort out
exhaust hits rear driveline....grrr
shift linkage binds on tunnel - need to drop the x/member a bit
get carb tuned so the thing will run right
get the interior/console fixed so i can mount the stereo instead of having it zip tied to the dash
also have to figure out the wiring dor the tranny - got some diagrams from here so will look at that this weekend
am really considering a paint job too - i have always wanted a British Racing Green car...so i may just do it (don't think i will ever own a Jag) i think the Brat would look cool in green...
a big thank you to this site:clap: everything went as it was stated here - these were the easiest upgrades i have done to any vehicle, the info gathered here is invaluable - thanks
will post more progress here as it happens.
#2 Mugs
Mugs
    Subaru Fanatic!
  • 546 posts
  • Spokane & Hobart, Wa.
Posted 25 January 2012 - 09:39 PM
Well its about time that you showed back up, and with an update too, pics included...priceless. :clap:
Waiting to see what lies ahead :popcorn:
When you gonna lift it and EJ it :brow: ;)
#3 wallaby
wallaby
    USMB Regular
  • 175 posts
  • clarkston,wa
Posted 26 January 2012 - 06:00 PM
if it gets a lift it will be very small - 1-2" to clear some cooler/tougher tyres
EJ may be in the future but we'll go with what we have for now...
i want to get the rest of it organized first - interior, paint, barwork etc
i figured i would get in trouble if i didn't have pics:D
will try to get one soon with the whole stable of brats (3)
#4 BratWarrior
BratWarrior
    USMB Regular
  • 168 posts
  • Portland
Posted 26 January 2012 - 07:31 PM
Repaint it, but keep the scheme. I think the light bile with darker decals looks ***************in'!
#5 wallaby
wallaby
    USMB Regular
  • 175 posts
  • clarkston,wa
Posted 06 February 2012 - 02:01 PM
did some more over the weekend,
finished the exhaust - blocked of the egr, and mounted the tailpipe, even had a big chrome ricer tip...:) exits right in front of the LH rear wheel - sounds good
also had to space the crossmember down about 3/16" to clear all the shift linkages on the tranny
then gave it a quick wash and took a couple pics
Posted Image
Posted Image
still have som interior work to do
i used all the console parts from the 85 so i have to fabricate something to transition from the dash to the console
that is where my stereo will mount - about where it is now but not zip tied......
Posted Image
then lined up the 2 running Brats
Posted Image
Posted Image
the brown one is my farm utility vehicle - gets used a heap around the farm
i just cut out all the rusty parts
it will be getting a kubota orange paintjob this spring
then finnally the black one will be my wifes farm vehicle -got it for $100 its pretty rusty in the floor and needs a little work to run and drive
then it gets painted bright yellow...:banana:
Posted Image
Edited by wallaby, 06 February 2012 - 02:07 PM.
add pics
#6 wallaby
wallaby
    USMB Regular
  • 175 posts
  • clarkston,wa
Posted 13 February 2012 - 04:33 PM
i have the Brat back on the road,
everything works well -
drives very different with the bigger/wider tyres
BUT
have a vibration/noise through the drivetrain under accelleration,
gets worse the harder you drive it, take it easy and it is not apparrent.
(and taking it easy is NOT an option.....)
driveline was professionally lengthened and balanced
could the flywheel be out of balance with the engine?
clutch was used but good, could it be out of whack?
seems to not happen while cruising
i am thinking i will remove the rear driveshaft and see if that makes a difference
any ideas???
#7 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 13 February 2012 - 04:56 PM
...then it gets painted bright yellow... :banana: ...
Gotta Love Yellow! :headbang:
Nice Brats, I Like how those six lugs Rims' Looks there, specially with the Beefier Tires on the Back.
Those rims Looks to have close like Stock offset.
Kind Regards.
#8 TeamCF
TeamCF
    Rocker panel smasher
  • 1,271 posts
  • Sandy, OR
Posted 13 February 2012 - 05:14 PM
Nice. You'll love that 5speed with the Weber. :)
The vibration could be tranny mounts. I know mine did that under hard acceleration. When I checked the mounts had ripped apart. At the time I jacked up the trans to where it needed to sit, cleaned them really good and used a bunch of 3M windoweld on them, that cured it. That was several months ago and it lost it's adhesion, proly didn't get them clean enough working under the car. I'm gonna buy some new mounts and beef them up with the stuff before putting them on. (I ended up using EA81 mounts on my 5speed, not as beefy as the EA82 mounts, but the fab work was easier at the time as it only required drilling a few new holes rather than making a custom crossmember)
A front inner DOJ will do that too (I've also had one of those happen years ago). But you noted that you just put new axles in.
#9 wallaby
wallaby
    USMB Regular
  • 175 posts
  • clarkston,wa
Posted 13 February 2012 - 06:19 PM
i did the same with tranny mounts -EA81 mounts and crossmember, just had to drill them to fit the 5 speed - they were pretty dodgy - maybe new ones would be the go...thanks
and yes the wheels are perfect...really like the fat tyres on the back:)
Edited by wallaby, 13 February 2012 - 06:21 PM.
#10 whistler
whistler
    USMB Regular
  • PipPipPip
  • 61 posts
  • Olympia
Posted 13 February 2012 - 08:25 PM
Hi I was wondering how the empi front axles fit on your brat. I recently replaced the front Driver's side axle on my 85 and it's rubbing on the steering column. I looked at my steering rack mounts but they look to be in good shape so I was wondering if you experienced any weirdness getting them in there. The axles that were on my brat had significantly smaller DOJ cups than the empis do but I was told that the cup size isn't related to the size or application of the axle and that as long as the splines were correct it should be okay. Anyway just wondering if you noticed a similar difference in size and whether it caused you any problems or anything.
Thanks
Tom
#11 wallaby
wallaby
    USMB Regular
  • 175 posts
  • clarkston,wa
Posted 17 February 2012 - 05:45 PM
empis fit just fine, except
they appear to be too short - the inner boot is
kind of stretched out, but they are working well
#12 tallwelder81
tallwelder81
    Eat, Live, Breath Subaru
  • 276 posts
  • maple valley
Posted 17 February 2012 - 07:27 PM
dont bother with 1" lift. completely pointless. not worth the trouble of the ten dollars of new bolts and washers.
go 2 in rear, 2.5 in front.
its mild and minimal, as you desire, but at least enough to be worth the time and energy.
if you lift it 1 inch, why not 3/4"? why not 0.5 inches?
i like the 2" option, cuz the driveshaft is still tucked up somewhat, and the exhaust is still out of danger. <mostly>.
#13 wallaby
wallaby
    USMB Regular
  • 175 posts
  • clarkston,wa
Posted 21 February 2012 - 03:31 PM
lift may come in time....
tyres clear at the moment, i like that it sits higher on the bigger tyres - i don't wheel it so i don't need a lift, i just want GOOD quality A/T tyres for gravel and farm roads. when these wear out i will be trying to fit a 27 x 8.5 or simmilar on it...might need a lift then.
for the moment it is giving me fits, had the carb tuned but the guy said he had to remove the PCV hose and block it off to make it run...???
so i changed the PCV valve for another used one - seems to work right now...
the guy also said i should run premium in it.....so i put $20 worth in to see what happens,i'm not convinced - uses more fuel, no noticalbe difference in power. also seems to have less power now, dosen't pull hills like it did when the engine leaked and the carb idled at 2500 rpm?????
does the 5 speed have a different 4th gear ratio - i thought it was a 1:1 like the 4 speed
my cooling fan is not working at all and it runs really hot - even on the highway and it blow coolant out...
my suspicion is a head gasket but the symtoms are incomplete????
i will get to fixing the trans mount this weekend too, might be able to drive it harder then:):)
